Application dialog? - Project orginization
I have an application that starts with Revit and works file. I want add a dialog to enable/disable it and provide options, how would I organize that project? I have applications that create a ribbon, and that ribbon button calls a separate command. Would I just have that button reference a command within the same dll?
And for testing, would I load the application and command separately from the respective tabs in the add-in manager?
Now that I've typed that out it seems straight forward enough, but it didn't a minute ago. Is that the correct approach? Have I overlooked anything? Thanks.
jeremytammik
Dear Bryan,
Thank you for your query.
Sure, that all sounds sensible to me.
I can't really think of much more to say off-hand.
There are other options in some detailed aspects, of course.
For instance, I don't use the add-in manager, just add-in manifest files.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
