A project with an Output Tyoe of Class...
Hi
I know this question has been up before, but I suppose I'm too much of a rookie with programming to fully understand the answers provided in different forums and blogs.
I updated a code to 2017 and it buids without errors, but i get this message:
I understand that a Class can't be run as startup, but it has worked in 2014-16. Whats the difference?
I tried to choose the project as Set as startup Project but it doesn't help. When i right-click it and assign it, the properties is still empty:
I've checked the box Use Managed Compatibility Mode.
This is the beginning of the code, if it helps.
namespace BSK_Tools { [TransactionAttribute(TransactionMode.Manual)] public class BSK_ToolsRibbon : IExternalApplication { static string AddInPath = typeof(BSK_ToolsRibbon).Assembly.Location; static string ButtonIconsFolder = Path.GetDirectoryName(AddInPath); string assembly = @"\\stofile01\filestorage\Liljestrand Fastigheter\Dokument\LFAB_tools\BSK_Tools.dll"; public Result OnStartup(UIControlledApplication a) { a.CreateRibbonTab("LFAB"); //Paneler RibbonPanel BSKPanela = a.CreateRibbonPanel("LFAB", "View"); RibbonPanel BSKPanela2 = a.CreateRibbonPanel("LFAB", "Annotation"); RibbonPanel BSKPanelM = a.CreateRibbonPanel("LFAB", "Manage"); RibbonPanel BSKPanelb = a.CreateRibbonPanel("LFAB", "Standards"); //Panel a buttons PushButtonData pushButtona1 = new PushButtonData("Remove\nUnderlay", "Remove\nUnderlay", AddInPath, "BSK_Tools.Remove_Underlay"); pushButtona1.LargeImage = new BitmapImage(new Uri(@"\\stofile01\filestorage\Liljestrand Fastigheter\Dokument\LFAB_tools\Underlay1.png")); pushButtona1.ToolTip = "Sätter parametern Underlay i alla vyer till None";
Even if i run it with the manifest i Revit I get the ribbon with panels but no buttons. Is there something in between there...?
Thankful for every tip...
Type x and y with every move in AutoCad and no one bats an eye...but use coordinates in Revit and everybody loses their mind.
