Can I use Window instead of Page when making my dialog dockable?
I want to create a dockable dialog that will contain UI elements.
I have created the dialog using WPF Window class but it seems that Revit only allows Dialog that implements Page and Autodesk.Revit.UI.IDockablePaneProvider.
Can I use Window instead of Page and make it work?
I tried using UserControl and it worked fine. But my dialog is developed using Window.
jeremytammik
Nope.
Sorry!
Jeremy Tammik
Developer Technical Services
The Building Coder
Hey Jeremy, thanks for replying.
Window can't be used - you've confirmed it. But what about UserControl?
I tried to create dockable dialog with UserControl and it worked. It means we have two options: Page and UserControl. Which one will you recommend and why?
jeremytammik
I only know that UserControl can be used.
I previously did not know that Page can be used as well.
Jeremy Tammik
The Building Coder
Okay. Thanks. I'll use UserControl then.
