Angle from Transform Matrix returns wrong value for assemblies
I am using a matrix calculation ( angle = acos ((basisX.x + basisY.Y + basisZ.Z -1)/2) ) to return the rotation angle of assemblies. I have been using this for a couple of months without any problems. However a few assemblies seem to return a wrong value in my last project.
Using the post 'Get Angle from Transform.BasisX, BasisY and BasisZ' (https://forums.autodesk.com/t5/revit-api-forum/get-angle-from-transform-basisx-basisy-and-basisz/td-...) I have also calculated the angle.
In my example assembly 'WA045' returns the same values for both calculations (this assembly has a correct rotation). However assembly 'WA014' returns two different values of which '204 degrees (or 24; anything at a 90 deg angle from 114 deg)' seems to be correct, but the value of '156 deg' from the matrix calculation is wrong.
Is my approach faulty or am I missing something?
regards,
Raymond
JimJia
Dear Raymond,
The value that acos returns will be [0,pi], so the matrix calculation return '156 deg' is correct.
acos method can not return value greater than '180 deg'.
please notice that '204 deg' + '156 deg' = '360 deg'
Actually the angle between two vectors is correct.
If you want to get the value '204 deg', you need to consider the direction of the vector.
I think you can use XYZ.AngleOnPlaneTo Method, it will return a value between 0 and 2*pi.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
BenoitE&A
Or you need to complete your angle calculation by another, checking whether your angle is between 0 and Pi or between Pi and 2*Pi.
I do this using the sign of the dotproduct of my vector and the local y axis. If the product is >0 then my angle is between 0 and Pi, in the other case it is between Pi and 2*Pi
Be careful if you do this that the searched angle is 2*Pi - calculatedAngle when it is between Pi and 2*Pi (and not Pi+calculatedAngle).
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Thanks for the suggestions. I will go and have a look 🙂
