Analytical model filtering for FilteredElementsCollector?
WorldDue
WorldDue
 UIApplication uiApp = commandData.Application;
            Document doc = uiApp.ActiveUIDocument.Document;
            FilterIntegerRule rule = new FilterIntegerRule(new ParameterValueProvider(new ElementId(BuiltInParameter.STRUCTURAL_ANALYTICAL_MODEL)), new FilterNumericEquals(), 1);
            ElementParameterFilter filter = new ElementParameterFilter(rule);
            FilteredElementCollector filterCol = new FilteredElementCollector(doc);
            filterCol.Where(e => e.CanHaveAnalyticalModel()); //This absolutely did nothing???!
            filterCol.WhereElementIsNotElementType();
            filterCol.WherePasses(filter);
            var eleList = (List<Element>)filterCol.ToElements();
            if(eleList.Count==0)
                TaskDialog.Show("Hint", "There are no enabled AnalyticalModels");
            foreach (Element e in eleList)
                using (Transaction trans = new Transaction(doc))
                    trans.Start("Disabling Analytical Model");
                   bool success= e.get_Parameter(BuiltInParameter.STRUCTURAL_ANALYTICAL_MODEL).Set(0);
                    trans.Commit();
I have noticed that this code can filter elements based on which have enabled analytical model to disable them, however if I used the linq where extended function to query for any element that can have analytical models, without filtering for this custom rule made in the above code, it just gives back many irrelevant elements? I wonder why did this happen?
RPTHOMAS108
Lots of things you wouldn't imagine can have an analytical model but not in reality.
Fewer have STRUCTURAL_ANALYTICAL_MODEL built-in parameter with .IsReadOnly = false
Are you saying the filter doesn't work, try it with a wall sweep (OST_Cornices). I believe the problem is that common base elements allow analytical models e.g. You can't set it on an architectural wall but you can if you turn the wall into a structural wall, however the wall class returns true since it can have analytical model depending on form of wall.
WorldDue
Thing is, it even picked up Levels and annotation models...
RPTHOMAS108
Probably not working then as Levels return false for .CanHaveAnalyticalModel (like all other annotation categories).
C#
UIApplication App = commandData.Application;
            Document Doc = App.ActiveUIDocument.Document;
            const BuiltInParameter AmP = BuiltInParameter.STRUCTURAL_ANALYTICAL_MODEL;
            FilteredElementCollector FEC = new FilteredElementCollector(Doc);
            IEnumerable<Element> Ien = FEC.WhereElementIsNotElementType().Where(J => J.CanHaveAnalyticalModel() == true)
                .Where(jx => jx.get_Parameter(AmP).AsInteger() == 1);
            using (Transaction Tx = new Transaction(Doc, "Disable analytical model"))
                if (Tx.Start() == TransactionStatus.Started)
                    foreach (Element item in Ien)
                        item.get_Parameter(AmP).Set(0);
                    Tx.Commit();
            return Result.Succeeded;
VB
       Dim App As UIApplication = commandData.Application
        Dim Doc As Document = App.ActiveUIDocument.Document
        Const AmP As BuiltInParameter = BuiltInParameter.STRUCTURAL_ANALYTICAL_MODEL
        Dim FEC As New FilteredElementCollector(Doc)
        Dim Ien As IEnumerable(Of Element) = FEC.WhereElementIsNotElementType.Where(Function(J) J.CanHaveAnalyticalModel = True). _
            Where(Function(jx) jx.Parameter(AmP).AsInteger = 1)
        Using Tx As New Transaction(Doc, "Disable analytical model")
            If Tx.Start = TransactionStatus.Started Then
                For Each item As Element In Ien
                    item.Parameter(AmP).Set(0)
                Next
                Tx.Commit()
            End If
        End Using
        Return Result.Succeeded
RPTHOMAS108
In the above you should add the check for .IsReadOnly as originally noted.
hvdsidf
Dear All,
I run your code but there is an error as below:
And in Revit, it shows this message:
Please help me, I'm a beginner with Revit API.
Thanks alot for your help  and Best Regards,
