Remove Add-in?
Remove Add-in?
reubeno_peddlethorp
Remove Add-in?
reubeno_peddlethorp
I've had a hunt around and can't seem to find the specific answer to this issue.  There are threads relating to Add-Ins but none of the solutions have fixed my problem.
I had installed an Add-In which subsequently hasn't seemed to work so I'm trying to remove it.  I get this message (twice!) every time I fire up Revit (2017).  I've tried removing all trace of the add-in but this message persists.
I've deleted the folder entirely from the location shown in the message but with no effect. I've searched my whole drive for the *.dll file but it's not there. The Add-In is not shown when Revit is running.
Is this an Issue with something latent in Revit itself or is there an instance of this file somewhere I'm not considering?
Thanks.
stever66
Search for a file with a .addin extension.   These are the files Revit uses to load dll files.
It is probably in:
C:\ProgramData\Autodesk\Revit\Addins\2017\
C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Addins
C:\ProgramData\Autodesk\ApplicationPlugins
or something similar.
You should be able to open the .addin file with notepad or word, and it should have a line with the path to the Otis program listed.   Then, you know you have the right file.
Also, you can just change the extension to a ".old".  That way it won't load, but the file will still be there if you find out you need it later.
reubeno_peddlethorp
No likely files in those locations that I can see.  Is there a way to stop Revit even looking for that particular add-in?
JimJia
Dear reubeno_archimedia,
If you want to remove an add-in, you need to remove its own .addin file or remove from other .addin file under
please try to find content in .addin file like below
<AddIn Type="Application">
<Name>Otis Typical Elevator Application</Name>
<Assembly>"C:\ProgramData\Autodesk\Revit\Otis\Otis_RevitPlugin2017.dll"</Assembly>
<AddInId>...</AddInId>
<FullClassName>...</FullClassName>
<VendorId>...</VendorId>
<VendorDescription>...</VendorDescription>
</AddIn>
then remove all
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
reubeno_peddlethorp
I found the offending file.  Turns out 'TypicalGenerator2017.addin' is what was causing the problem.  Very helpful file name there...Otis, I'm looking at you.
Couldn't find a way to make windows search the contents of the file for text (even by changign the file indexing), but managed to find it by elimination.  Thankfully I don't have that many to run through.
Thank you both for your help.
Had the same problem and this worked for me.  Thanks!
pattydickman1373
Thanks for posting the file name!
