All elements in a active view
Hi!
How can I get all the elements of all categories available in a active view? Must I use a filteredCollectorElement?
  • API
lukaskohout
Yes.
It is the best way to collect the elements from any document. You can directly pass the ActiveView.Id to the FilteredElementCollector overload to collect only elements visible in that view.
var col = new FilteredElementCollector(doc, doc.ActiveView.Id).
   Cast<Element>().
   ToList();
Hitting Accepted Answer is a Community Contribution from me as well as from you.
TEK1
For anyone reading this in future sometimes you might want to add a filter (I know that I did).
For example, here is a snippet i ripped out from an addin i was developing.
FilteredElementCollector filter = new FilteredElementCollector(doc, doc.ActiveView.Id);
var filteredDimensions = filter.WherePasses(new ElementClassFilter(typeof(Dimension)))
      .ToElements()
      .Cast<Dimension>()
      .Where(d => dimensionIsGood(d))
// we can filter IN dimensions
// and filter out via any condition we want
karim_mostafaVM84V
it throw an Exception if View is of type ViewSheet
regards
karim Abdelrazek
