set value to a Read-only parameter
I have an familytype ant its category is "electricalEquipment"
then the family instance has a parameter "Instacance_elevation_param"
when create instance in Revit, I can modify the parameter
but after confirm it then the parameter is read-only
then my question is : how I can set the parameter in code
document.create.newfamilyinstance(); (I have try to set the location XYZ  but useless)
lukaskohout
Is the parameter created by user in the family or is it built-in parameter?
Could you post some screenshot and maybe the family of Electrical Equipment?
Hitting Accepted Answer is a Community Contribution from me as well as from you.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Are you trying to set the instance parameter value to an element before creating/placing an element in the project?
Please note that the instance parameter is accessible via API only after creating an element instance in the project.
1)create a transaction
2)place an element in the project
3)commit the transaction(An instance element is created)
4)Create one more transaction
5)Modify parameter value
6)Commit the transaction
Also, check for the parameter's properties before modifying the parameter.
If the parameter value is read-only then the value of parameter cannot be changed via API.
Some parameters are read-only but User-modifiable which means the parameter value can be changed via UI but not via API.
Here is the recent discussion
https://forums.autodesk.com/t5/revit-api-forum/modify-key-source-parameter/m-p/9592801#M47989
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
