Add Points to TopographySurface Error: Not permitted to start
Hello
I am attempting to add points/vertices to an existing TopographySurface(TS) element. I understand that in order to add points to an existing TS I need to start a TopographyEditScope. But when I start my TopographyEditScopeI get the following runtime error:
Revit encountered a Autodesk.Revit.Exceptions.InvalidOperationException: TopographyEditScope is not permitted to start at this moment for 1 of the following possible reasons: The document is in read-only state, or the document is crrently modifiable, or there already is a topography surface edit mode active in the document.
How can I overcome this error? You'll see below that my very simple code is not running another TopographyEditScope so thats not the cause. Also I am correctly running my TopographyEditScope from within a Transaction (which is what is required). Also my Revit project is of the type Construction if that helps.
Any solutions and advice would be extremely helpful:
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class MyGroup : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIApplication uiApp = commandData.Application;
        Document doc = uiApp.ActiveUIDocument.Document;
        Transaction trans = new Transaction(doc);
        trans.Start("Lab");
        List<XYZ> pnts = new List<XYZ>();
        pnts.Add(new XYZ(-5, -5, 0));
        pnts.Add(new XYZ(0, 5, 5));
        pnts.Add(new XYZ(2, 2, 2));
        TopographySurface surface = TopographySurface.Create(doc, pnts);
        TopographyEditScope scope = new TopographyEditScope(doc, "blah");
        scope.Start(surface.Id);  // Runtime error occurs at this line
        List<XYZ> pList = new List<XYZ>();
        pList.Add(new XYZ(5, 5, 5));
        pList.Add(new XYZ(5, 0, 0));
        pList.Add(new XYZ(3, 3, 3));
        surface.AddPoints(pList);
		MyFailureProcessor failProc = new MyFailureProcessor();
        scope.Commit(failProc);
        trans.Commit();
        return Result.Succeeded;
    class MyFailureProcessor : IFailuresPreprocessor
        public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor)
// TODO: implement code return FailureProcessingResult.Continue; } } }
Hello Sam,
The error you get is because there is a problem with transaction order. I changed the code like this and it works like a charm 🙂
trans.Start("Lab");
trans.Commit();
trans = new Transaction(doc);  // added an extra transaction here
trans.Start("Lab2");
trans.Commit(); // close it and then commit the scope, otherwise you'll get the same error.
Looks like TopographyEditScope is threated by Revit the same way as a transaction.
Good luck with your program,
Remy.
It works now. Thanks 🙂 Its greatly appreciated
