Add Panels in CurtainWall
Hi Revit,
I create a curtainWall (defined in Revit family) via API in this way:
Wall wall= Wall.Create(doc, line, levelBottomId, false);
wall.WallType = newWallType;
 if (wall.WallType.Kind == WallKind.Curtain)
       //how to split it in panels?
       CurtainGrid grid= wall.CurtainGrid;
        grid.AddGridLine(false, point, false);
I want to split the wall in some panels. is it right? how to complete the command?
Bruno
What 'point' are you setting? I would imagine you want the XYZ to be somewhere along the length of the wall. Try getting the midpoint of the wall and using that point.
I have followed your suggestion and it didn't work.
I understood why (my fault):
you must create the wall in transaction ONE, commit, and in transaction TWO add the grid line. Now it works.
Thank you,
Bruno
