Add formula to schedules
rinku.khatri
rinku.khatri
I am trying to create ViewSchedules through api in revit 2022, and got stuck when trying to add formula to fields.
Is there a method which i can use for this.
jeremy_tammik
I searched this forum to "schedule formula" and see a number of previous discussions with several solved questions:
Have you taken a look at those, to see whether this question has already been discussed and solved in the past?
rinku.khatri
Hi Jeremy,
Thank you for the response, I did go through all those posts and most of them suggest that its not possible to add calculated fields programmatically. However those are posts about older versions of revit so I wanted to know if there has been a change.
jeremy_tammik
Oh dear, sorry about that. In that case, one thing to do is to add your vote and an explanation of your requirements to an appropriate Revit Idea Station wish list item. This looks like a suitable candidate:
https://forums.autodesk.com/t5/revit-ideas/api-create-a-calculated-value-field-in-schedule/idi-p/806...
