Add a row to a schedule
Message 1 of 8
I want to add a row into a revit (key) schedule
My code:
TableData tableData = viewSchedule.GetTableData();
TableSectionData tsd = tableData.GetSectionData(SectionType.Body);
tsd.InsertRow(tsd.FirstRowNumber );
tsd.SetCellText(tsd.FirstRowNumber + 1, tsd.FirstColumnNumber, "Schedule of column top and base levels with offsets");
This is the same code as given in: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
but somehow I get a ModificationOutsideTransactionException
Replies (7)
Message 2 of 8
BenoitE&A
Hey,
Modifications of the document need to be inserted in a Transaction.
See here for a description of how it works.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...
And be careful to the parameter of your MainClass (in this line the TransactionMode needs to be in Manual)
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
Cheers
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Message 3 of 8
Thank you, but what does "An exception will be thrown if a transaction is started from an outside thread or outside modeless dialog." mean?
Message 4 of 8
This is my whole code:
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    class Elementabgleich : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            View activeView = commandData.View;
            if (activeView is ViewSchedule)
                ViewSchedule CellsToAdd = activeView as ViewSchedule;
                TableData tableData = CellsToAdd.GetTableData();
                tsd.InsertRow(1);
} else { TaskDialog.Show("Wrong View", "Change View"); } return Result.Succeeded; }
Message 5 of 8
BenoitE&A
So :
- the error you mention means you can't have Transactions in 2 threads simultaneously. You can search in the web what threads are if interested. But it is easy to understand when you understand what transactions are for : encapsulate the modifications you make to the model so that you can cancel them (the use of the Cancel button of Revit is possible). So Revit denies you the possibility to make modifications in 2 threads at the same time, since they can have effects one to the other and you could not undo them.
- in your code the 2 lines starting with tsd are modifications of the model and need to be encapsulated in a
using(Transaction t = new Transaction(myDoc, "myTrans")
block
Benoit
Benoit FAVRE
Message 6 of 8
after implementing you code, I still get the same error
                using (Transaction t = new Transaction(doc, "myTrans"))
                    tsd.InsertRow(1);
Message 7 of 8
BenoitE&A
t.Start();
blabla
t.Commit();
Please, read the guides...
Benoit FAVRE
Message 8 of 8
thank you so much, this worked 🙂
