Can´t insert text into schedule cell
Hi I want set text to a schedule.
Here is the code I got so far:
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            View activeView = commandData.View;
            if (activeView is ViewSchedule)
                ViewSchedule CellsToAdd = activeView as ViewSchedule;
                TableData tableData = CellsToAdd.GetTableData();
                TableSectionData tsd = tableData.GetSectionData(SectionType.Header);
                using (Transaction t = new Transaction(doc, "myTrans"))
                    t.Start();
                    tsd.SetCellText(tsd.LastColumnNumber-1, tsd.LastColumnNumber-1, "new Text");
                    t.Commit();
But whenever I run the programm I get a "ArgumentException" which tells me: The given row number nRow is invalid.
How can I fix that?
RPTHOMAS108
You've used 'tsd.LastColumnNumber' twice and have not used '.LastRowNumber' (if this was your intent).
I'm not sure if the indexing is zero based or one based therefore try without the -1 part.
