Active document window handle
prakash.muthu
prakash.muthu
Looking for an API to get active window handle of current document in display. Trying to find the highlighted area view window handle.
Thank you.
Moustafa_K
using UIframework.dll (part of Revit installation) and
using Xceed.Wpf.AvalonDock.dll (part of Revit installation) and
using Microsoft.VisualStudio.Utilities nuget
you can get that via this code:
 var docControl = MainWindow.getMainWnd().FindDescendant<LayoutDocumentControl>();
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
prakash.muthu
Getting error on using above code.
'MainWindow' does not contain a definition for 'FindDescendant' and no accessible extension method 'FindDescendant' accepting a first argument of type 'MainWindow' could be found (are you missing a using directive or an assembly reference?)
Do i need to add more references?
prakash.muthu
Thank you Mustafa. Now able to get the control. Further how to get the window handle and mapping it with specific document.
Moustafa_K
you can get the handle using PresentationSource
var hwndSource = PresentationSource.FromVisual(docControl) as HwndSource;
var handle = hwndSource.Handle;
Moustafa Khalil
