Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Active document window handle
4 REPLIES 4
prakash.muthu
286 Views, 4 Replies
Looking for an API to get active window handle of current document in display. Trying to find the highlighted area view window handle.
Thank you.
4 REPLIES 4
Moustafa_K
in reply to: prakash.muthu
using UIframework.dll (part of Revit installation) and
using Xceed.Wpf.AvalonDock.dll (part of Revit installation) and
using Microsoft.VisualStudio.Utilities nuget
you can get that via this code:
 var docControl = MainWindow.getMainWnd().FindDescendant<LayoutDocumentControl>();
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
prakash.muthu
in reply to: Moustafa_K
Getting error on using above code.
'MainWindow' does not contain a definition for 'FindDescendant' and no accessible extension method 'FindDescendant' accepting a first argument of type 'MainWindow' could be found (are you missing a using directive or an assembly reference?)
Do i need to add more references?
prakash.muthu
Thank you Mustafa. Now able to get the control. Further how to get the window handle and mapping it with specific document.
Moustafa_K
you can get the handle using PresentationSource
var hwndSource = PresentationSource.FromVisual(docControl) as HwndSource;
var handle = hwndSource.Handle;
Moustafa Khalil
