Accessing Revit context menus
Kevin.Bell
Advisor Advisor
Message 1 of 8
Kevin.Bell
I'm in the process of writing a small plugin which would act as a project browser and do various things which would be helpful to me.
The current project browser allows the user to right click on a view to access thinks like 'Duplicate View' or 'Rename' etc.
Is there any way I can 'link' to the context menu from addin, so the user right clicks and I get Revit to display the appropriate menu?
Or alternatively, is there any way to create a right click menu (I can't see anything in the API documentation).
Replies (7)
Message 2 of 8
jeremytammik
Afaik, the Revit API does not provide any support for this.
However, there is nothing to stop you from using the .NET functionality to access and manipulate the context menus to your heart's content.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 8
Kevin.Bell
Thanks for the reply Jeremy, but I don't follow what you mean by 'access and manipulate the context menus' as you said there was no support for this?
Do you mean - create my own context menus?
Thanks.
Message 4 of 8
jeremytammik
Nope, I meant 'use the native Windows API and .NET library functionality to access and manipulate existing context menus'. In Windows, you can do almost anything you like in the user interface, including hook into other applications' context menus, cf.:
https://stackoverflow.com/search?q=%22context+menu%22+windows
Jeremy Tammik
The Building Coder
Message 5 of 8
Kevin.Bell
Thanks for your reply, I'll take a look.
Message 6 of 8
BobbyC.Jones
Are you right clicking items on your own dialog?  If so, you can just create your own context menu
WPF
https://www.google.com/search?q=wpf+context+menu
Windows Forms
https://www.google.com/search?q=windows+forms+context+menu
Bobby C. Jones
Message 7 of 8
Kevin.Bell
I was hoping to link into Revit's menus, and maybe the commands would run from the menu.
So for example, when the user right clicks on Sheets node in the Project browser a menu pops up and allow the creation of a new sheet etc - I was hoping to somehow link to the menu so I would not have to create my own and create similar menu options commands....
Message 8 of 8
Kevin.Bell
I should add, that If I can't access Revit's menu then I'll have to create my own using WPF as you say...
