Missing AdSSO.msi
Missing AdSSO.msi
The feature you are trying to use is on a network resource that is unavalible.
click ok to try again or enter an alternate path to a folder containing the installation package AdSSO.msi in the box below.
Where can i download this package, or where can i find it?
In version 2019 i found them manually after searching in many different folders.
Martin.
jeremytammik
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
If you are not doing anything programmatically,  this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
