Abstract CommandClass for IExternalCommand
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have starting using Revit for about 2 weeks and most of 1 week was spent on another project that uses AutoCAD.
So I am just getting familiar with Revit and have only looked at API briefly, and without a good strong understanding of the fundamentals of the API it hard to know what are good parts to abstract out for reusable libraries.
The limited examples and templates I have seen implicitly implements IExternalCommand.
I was wondering why not explicitly implement IExternalCommand in base classes for common command functionality?
So I guess the main question would be does Revit always call Execute through IExternalCommand interface?
If I am not being clear enough would the below example be a safe practice to use?
This might be common practice I just have not seen it mentioned or used in the limited examples I have seen.
This example only saves a little typing and just assigns some properties to commonly needed objects in a command.
Base Command class
using System; using System.Collections.Generic; using System.Linq; using System.Text; using Autodesk.Revit.DB; namespace Autodesk.Revit.UI { public abstract class CommandClass : IExternalCommand { protected ExternalCommandData CommandData { get; private set; } protected UIApplication UIApp { get; private set; } protected Document Doc { get; private set; } Result IExternalCommand.Execute(ExternalCommandData commandData, ref string message, DB.ElementSet elements) { this.CommandData = commandData; this.UIApp = CommandData.Application; this.Doc = UIApp.ActiveUIDocument.Document; return this.Execute(commandData, ref message, elements); } public abstract Result Execute(ExternalCommandData commandData, ref string message, DB.ElementSet elements); } }
So if you took the example Lesson 1 from My First Plug-in Training and inherited class above it would be changed to
[TransactionAttribute(TransactionMode.Manual)] [RegenerationAttribute(RegenerationOption.Manual)] public class Lab1PlaceGroup : CommandClass { public override Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { //Define a Reference object to accept the pick result. Reference pickedRef = null; //Pick a group Selection sel = UIApp.ActiveUIDocument.Selection; pickedRef = sel.PickObject(ObjectType.Element, "Please select a group"); Element elem = Doc.GetElement(pickedRef); Group group = elem as Group; //Pick a point XYZ point = sel.PickPoint("Please pick a point to place group"); //Place the group Transaction trans = new Transaction(Doc); trans.Start("Lab"); Doc.Create.PlaceGroup(point, group.GroupType); trans.Commit(); return Result.Succeeded; } }
The one quick test I did worked and that is not saying much unless it would Always work.
With limited knowledge I do not know what functionality would be useful to place in class and just wondering if it would be safe to explicitly implement IExternalCommand in base class for Revit to call Execute.
