about Element ID...
about Element ID...
XARMA
about Element ID...
XARMA
hi, I need some help.. please advise me
Can I get same Element ID in rvt file copied or detached ??
revit assign different Element ID to all of element, eventhough it's same model just copied or detached. who can solve it clearly?
jeremy_tammik
You are in luck. I recently published a collection of references to many previous discussions on the behaviour and properties of various BIM element identifiers:
The ElementId is assigned per document. Afaik, it only changes if several copies of the same document exist, are edited independently, and need to be unified back into a single consistent state, e.g., by checking out, editing, and checking back in different worksets.
Other than that, the ElementId remains constant. Obviously, copying a model leaves the ids unchanged. For all further details, please refer to the compilation above.
XARMA
Thank you for your answer.
I am learning that link !
