Can I include parameter name in formula? (.rfa)
XARMA
XARMA
Hi I need some help.. please consider about problem like this.
sometimes parameter names are related with values.
currently, in my case, I have 9 essential parameter. it's as follows.
Parameter name : ConnectorNo1, ConnectorNo2, ... ConnectorNo9
Values : 'Familyname'C1, 'Familyname'C2, ... 'Familyname'C9
they are rely on rfa file name 'Familyname'.
I want to unify as one values.
so I have to make last Alphabet to parameter that I can include in formula.
is it possible? sorry for my bad English.. if you don't understand it, I can explain again.
Thank you in advance.
jeremy_tammik
I assume you are talking about formulas that you define manually in the Revit end user interface. In that case, you will probably obtain better answers in the larger and more generic UI-oriented architectural forum:
XARMA
Sorry, I couldn't understand Sir.
Isn't it same Forum?
jeremy_tammik
Nope. This Revit API forum provides support for programmers using the API. The architectural forum supports users interacting with the Revit UI. It is large and more generic, providing deeper knowledge on optimal workflows and best practices for interacting with the BIM.
XARMA
Thank you for your information. I will refer it.
