I want to try and write a quick little add-in that will allow me to select a whole row of grids and flip the bubble to the other end of the gridline in the view.
I can access the GRID_BUBBLE_END_1 and GRID_BUBBLE_END_2 parameters but these are related to the Grid Type default settings and not the view specific 2D elements.
I have found myself having to do this manually many times, so as I learn the Revit API I thought that this would be a nice easy exercise to get me going.
I guess if this also falls into the same category of accessing the Elbow control, its handle element and the 2D extents
I have tried using the SNOOP tool on both the grid and the active view but can't find anything... surely this must be accessible via the API...???
Any help appreciated
Ian
Solved by Joe.Ye. Go to Solution.
