Dear Experts,
When we import pdf files in Autocad References files to get back data from that , we see several metadata things are there which are Revit specific. We have Revit License also. Can we get the elevation related informations , sections related informations and the level related cross mapping informations directly from these pdf files (anyhow in Revit?) since the pdf is generated through Revit.
That will help us to get the modeling related informations (for scope wise departments filtering) instead of over dependency on Revu like things
We have our inhouse semantic parser(Reading pdf file from scratch as binary reader and with specific lookup as per Revit and Advance Steel Experiences to read design documents) on pdf but that looks over work when several pdf commented type meta data is already there when the pdf is generated from the revit model itself. If we can get these metadata conditions inside pdf files then several RFI things can reduce and projects outputs can get faster
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
