2016 Hang Up
2016 Hang Up
znutsch
2016 Hang Up
znutsch
I'm not sure if this is the correct forum or not if it is not please let me know. But when I click on the 'open' underneath the 'projects' Revit freezes up on me. I checked like 3 or 4 different solutions to fix the problem and those did not work. Those solutions were the Windows button + R and disabling a few things and re enabling, The dropbox which I do not have, and a couple others. I currently have this as the build number Update 7 for R2
16.0.1185.0
20161004_0715, I'm not sure what I need to do.
If anyone can help that would be great. Again sorry if this is the wrong forum.
Zach
jeremytammik
Dear Zach,
Nope, sorry, wrong place.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
