Hi i'm Dicle'from Turkey.
Iam a REVIT user.I encountered a problem while getting the render.
Solved by anavaidya. Go to Solution.
Perhaps it contains too many import elements(cad plan import etc)
That's why it maybe not reading when a few import elements are overlaid.
i have fixed in this way and then gave an error again so idont know how i fix it now.
can someone help us ???
Hi @diclesalman and @Anonymous,
- Is this happening only with this particular file? Open a Revit sample file and render in Cloud. Are you able to render?
- Which version of Revot are you using? Please make sure you have the latest update installed. Link - http://knowledge.autodesk.com/support/revit-produc
- Also here are our FAQs - https://forums.autodesk.com/t5/a360-rendering-forum/frequently-asked-questions/td-p/5533974?nobounce=
Thank you for your attantion,
-Yes its happenning only with this file.When i opened a new revit file i was able to render.
-i am using revit 2015 how can i know latest update?
Thank you
I had this problem - but uninstalling Revit Live package allowed render in cloud to work as normal
