ReMake Forum
Welcome to Autodesk’s ReMake Forums. Share your knowledge, ask questions, and explore popular ReMake topics.
Project pending approval
10 REPLIES 10
Message 1 of 11
1377 Views, 10 Replies
Hey peeps,
I started using Remake this morning and I gotta say, it's good. Really really good, I've got an object done in a few minutes. The thing is, after I published it I deleted it to change some details and republish it while keeping the name, but since then I can't show it to anyone, because it says that the project is pending approval. Anyone had the same problem  =/ ?
10 REPLIES 10
Message 2 of 11
TatjanaDzambazova
Hi !
Autodesk has implemented a new monitoring of publishing on the Gallery and when an object is published twice it requires attention of admins ( like me) to make sure its correctly published. I am doing this every few days - i just approved few, can you tell me if you can see it now? tanja
Message 3 of 11
in reply to: TatjanaDzambazova
Hi Tanja,
Thanks for the reply. I understand, and I can see it now!
Best regards,
Carlos
Message 4 of 11
Even my project says pending approval.... this is for monthly challenge..... please approve it fast...
Email: sviswas1997@gmail.com
Message 5 of 11
Message 6 of 11
TatjanaDzambazova
Hi Sredhar,
so, we asked the Gallery team to allow projects to be automatically approved so that you dotn have to wait for approvals (and only remove projects later if they have any IP issues or similar)
i am trying to find out your project and see why this doesnt work...
tanja
Message 7 of 11
TatjanaDzambazova
btw, can you send a screenshot of your project and the message? i dont see a project under your name
Can you please tell me which version of ReMake are you using?
thanks
Message 8 of 11
Thank you
But please make it fast....
Message 9 of 11
Sir now it is uploaded
Message 10 of 11
dwest
I am also having a pending approval issue.
Message 11 of 11
gerald_chin
in reply to: dwest
Hi @dwest,
May I have more details on the problem that you are facing?
Cheers,
Gerald Chin
Senior User Experience Designer,
Autodesk Vault
