Project pending approval
Hey peeps,
I started using Remake this morning and I gotta say, it's good. Really really good, I've got an object done in a few minutes. The thing is, after I published it I deleted it to change some details and republish it while keeping the name, but since then I can't show it to anyone, because it says that the project is pending approval. Anyone had the same problem  =/ ?
Replies (10)
TatjanaDzambazova
Hi !
Autodesk has implemented a new monitoring of publishing on the Gallery and when an object is published twice it requires attention of admins ( like me) to make sure its correctly published. I am doing this every few days - i just approved few, can you tell me if you can see it now? tanja
Hi Tanja,
Thanks for the reply. I understand, and I can see it now!
Best regards,
Carlos
Even my project says pending approval.... this is for monthly challenge..... please approve it fast...
Email: sviswas1997@gmail.com
TatjanaDzambazova
Hi Sredhar,
so, we asked the Gallery team to allow projects to be automatically approved so that you dotn have to wait for approvals (and only remove projects later if they have any IP issues or similar)
i am trying to find out your project and see why this doesnt work...
tanja
TatjanaDzambazova
btw, can you send a screenshot of your project and the message? i dont see a project under your name
Can you please tell me which version of ReMake are you using?
thanks
Thank you
But please make it fast....
Sir now it is uploaded
dwest
I am also having a pending approval issue.
gerald_chin
Hi @dwest,
May I have more details on the problem that you are facing?
Cheers,
Gerald Chin
Senior User Experience Designer,
Autodesk Vault
