Survey Point Coordinates for aligned projects
ReCap has a very nice feature to auto-select the white target globes. Future selections of the same globes produce the exact same X,Y,Z values from the original scan data. When creating a new survey point using targets, I would like the top row of X, Y, Z values to still reflect the original scan position but the second row to reflect the newly aligned X, Y Z position of the project. See the attached screen shot.
2 Comments
After feedback from fellow ReCap user, the below graphic explains the idea much better.  (Thanks Larry!)  Also, Autodesk developers can simply give me a pull down option (down arrow) with the aligned location if you do not want to change 0,0,0.
I can export the X, Y, Z coordinations for annotations to a CSV file.  I can not export the target's X, Y, Z locations.  Can I please have the ability to export my white sphere's X, Y, Z target locations both BEFORE and AFTER ALIGNMENT.  Each target name would give me the corresponding X, Y, Z coordinates.  I would use all the white spheres as virtual surveyed monuments.  Right now I have to MANUALLY hand type each and every coordinate location.  This is very time consuming.ReCap surveyed target locations in AutoCAD.jpg
