Select points using CAD objects
We work with hybrid models:
the Recap Projects are attached in AutoCAD based applications to model the new things in the exising laserscan.
But often, we have to break down some existing things in order to attach the new things.
What I would like is that I am able to draw a Solid in AutoCAD (a basic solid like a box or a cylinder, to start with, a complex union of solids later on)
and then be able to select all Recap Points withing that solid to change them to another region to be able to make them invisible.
This functionality could be in Recap, but then we need to be able to attach a DWG as reference in Recap
OR it could be in AutoCAD (Inventor and Revit) as part of the functionality of the ReCap plug-in.
1 Comment
vidanom
