Can I please have an ETA on a fix for CLR files direct import? I work for authorized Topcon dealer in Canada. I know of the product release for ReCap functioning with direct import of CLR files, which are files directly off the scanner SD card (hence bypassing Topcon Scanmaster software for coloring scans). Topcon put out a release note saying it was now functional in Recap, months ago. I tested it that very same day and it didnt work, there was no way to import SEVERAL scans at once, as Recap sees them all as the same name.
I've noted this to Topcon a couple of months ago, at which time I was told Autodesk is aware of the problem, and the next release would have a better workflow for importing many scans at once in CLR format. It was noted that this release might be expected in October.
I have a very big demo opportunity in 2 weeks where I want to show off the Recap workflow for a customer that wants to bring scans into Revit, but as it stands I have to import and color them in Scanmaster, then into Recap, and it just isnt a very good workflow.
Any update on a fix? I've just signed up for a paid version of Recap Pro, but without this function it's not really worth it if I have to use Scanmaster anyway.
Thanks!
Mark
