Show only
Search instead for
Submitted byAnonymouson08-24-201607:27 AM
Status:
Implemented
permanent deletion of of point clouds
is it possible to permanently delete points in recap. when i delete points and save and optimize, everything looks good until i open the file in navisworks and everything shows up again, can someone help me with that please
The next version of Navisworks should support this. But you can also get rid of the points by doing a Save As and choosing the 'remove deleted points'.
This has been implemented in the ReCap engine and will be available in each product based in its individual schedule. Should be no later than the next major release (2018) for each, possibly earlier.
For workarounds, see the comment thread or the ReCap community forum.
The deletion of points still seems to be an issue. It is fine to save as a unified RCS file but if you need to use the file for data extraction in other programs such as Pointfuse and Edgewise that require scans that are not unified, the hard work of cleaning up the point cloud comes to nought. Edgewise can now import Recap files but even "Saved As" files still bring in the deleted points. All of the points appear again and then auto pipe extraction is done on the entire point cloud. Really frustrating.
