Multiple Recap Session Window
We are unable to run two Recap files in two different session in Autodesk Recap platform. Please add the option as it would be very beneficial for us.
7 Comments
mika_jahkola
Several instances of Recap on the same machine would be very helpful. I can see two uses:
1. View several projects at once. Typically we split large sites into several Recap projects. For example each floor and each stairway is a separate point cloud, or the inside and outside of a building are separate clouds. We frequently check details using RealView. There is no way to have two or more projects open at the same time but we have to close one before we can view the other.
2. Load and index Recap projects in the background while viewing another project. Now registration prevents using Recap for anything else at the same time.
daniel_musick
"As of version 3.0.1, ReCap 360 includes the ability to create ReCap projects from raw source files in an automated, background fashion. These features are accessible through a command-line executable import tool called DeCap.exe, located in the ReCap 360 install folder. The source files can be specified directly on the command line or provided in a control file."
https://knowledge.autodesk.com/support/recap/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Reality...
So at least the importing/indexing can be done in the background. I don't know if we are allowed to use DeCap and ReCap simultaneously.
And since Recap is losing features quicker than one can say "Cloud-Pusher", you have to try out for yourself whether it still works as not-advertised anywhere, which is why no one knows this feature is available.
...But if Autodesk itself is not aware that such a feature exists, it will not actively try to kill it.
Could still be dead through neglect....
culley.parris
Observer
YES Please.  Same issue here.  I would use multiple sessions all the time.  I scan large areas in separate zones to prevent unwanted "noise" from far away scans and to limit sizes of individual scan sets, which improves session performance.  I have plenty of Ram to support this.  COME ON!
Kevin_Laskowski
Any update? Would be great to index 10 projects simultaneously overnight. Instead of using 4 virtual machines running one instance of Recap at a time. Autodesk please look into this and bring more value to our workflow. It gets expensive adding more Virtual machines to keep up with the project.
yan.fu
Hi all,
Thanks all for your comments. While multiple instances of ReCap is not supported yet, you can run multiple DeCap.exe to index multiple projects on the same machine.
Yan
ramesh_sridharan
Status changed to: Archived
aryan_rashidA5WSA
Community Visitor
Any update on running multiple ReCap sessions at the same time?
