annuler
Affichage des résultats de
Afficher  uniquement  | Rechercher plutôt
Vouliez-vous dire :
Multiple Open Projects in Recap
You should be able to have multiple projects open at once, like a lot of the other Autodesk products. A lot of times I'm modeling from a point cloud in Revit, and it's very helpful to view the panoramas, but I also have another project that I want to register at the same time. Right now I can only do one or the other in Recap.
4 Commentaires
Non applicable
i agree.  at times i come back from a day of scanning with 3 or 4 different rooms, to make 3 or 4 separate clouds, only to be able to only process 1 at a time.
vidanom
Statut modifié en : Under Review
jamescope
Agree. I like to use ReCap for checking smaller areas of a large scans. I do most of my registration in my scanner manufacturers software, but I like to check smaller parts for alignment, matching, coverage, etc in ReCap. Ideally, we would be able to open multiple instances of ReCap just like other Autodesk products, i.e., AutoCAD, Navisworks, etc.
barmanr
Hi, We have included the ability to run multiple instances of ReCap Pro in 2026.1 Beta just released: https://forums.autodesk.com/t5/recap-forum/recap-2026-1-beta-participation/td-p/13707448 Warmest Regards,
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
Proposer une idée
