higher point density needed
The limit of 1 pt/cm^3 is too large for many applications. Even with decimation off entirely I loose between 66-75% of my data when coming into recap. This makes my finished project transparent and impossible to see easily in inventor since there is no point size adjustment there. My data has already been run through filters to remove excess data and kept what I need. Why does your software think that it knows what I need. If you are going to have your own decimation filter remove the 1 pt/cm^3 limit, it makes no sense.
1 Comment
yan.fu
The limit in ReCap is 1pt/mm^3. Please check your import setting or raw scan point coordinate unit before importing the scan. If there is something not clear, please feel free to contact our technical specialist for support. Thank you!
