I would like to filter classified point cloud data in Recap so that a point cloud containing only ground data can be brought into C3D. C3D's filter method would be sufficient if the data is not classified but is not desirable when the data can be filtered. This was possible in C3D 2017 but with updates to software that functionality has gone away and we need a better way to filter the point cloud data. There is as way using "MAPCREATEPCSURFACE" to filter the data and create a DEM file to create a surface but when I do that the surface doesn't lay on the DEM which is frustrating. The "MAPCREATEPCSURFACE" work around adds another step to the workflow when it should be an included function.
