ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Registration problem
2 REPLIES 2
398 Views, 2 Replies
Hi. i have a project with +-600 scans. when i register them manually it works fine up until a point. then suddenly it puts all my scans in a small area and then its no spread over the area that i have scaned. its almost as if all the scans suddenly attracted each other and then its a mess. Has anyone had this before or a solution. I had a project with more scans and that one worked fine. Any assistance will be appreciated.
2 REPLIES 2
The same thing happened to me with a 250 scans project.
The only think i could tell you, it's to separate your project in smallers projects and you register the projects together.
Good luck.
ashwini.murthy
We released an update a few days ago - version 3.1.2.4 that fixes a registration bug. The bug is very similar to what you are describing.
Details on this update can be found in the post pinned at the top of this forum http://forums.autodesk.com/t5/recap-360-forum/autodesk-recap-360-autodesk-recap-360-pro-update-3-1-3...
Please apply this update and let us know if you still see any issues.
Ashwini
Rail Community
