Solved by ashwini.murthy. Go to Solution.
The same thing happened to me with a 250 scans project.
The only think i could tell you, it's to separate your project in smallers projects and you register the projects together.
Good luck.
We released an update a few days ago - version 3.1.2.4 that fixes a registration bug. The bug is very similar to what you are describing.
Details on this update can be found in the post pinned at the top of this forum http://forums.autodesk.com/t5/recap-360-forum/autodesk-recap-360-autodesk-recap-360-pro-update-3-1-3...
Please apply this update and let us know if you still see any issues.
Ashwini
