ReCap Pro & ReCap Photo student licence?
Message 1 of 40
I am teaching Civil 3D and ReMake.
I was told to switch to ReCap Photo, when I opened ReMake today.
I downloaded ReCap Photo via students.autodesk.com. After installation I only have two options: 30 day trail or subscribe.
Where do I put the Serial Number / Product Key / etc. in order to create models for free?
Replies (39)
Message 2 of 40
I'm having the same issue... I've been going around in circles with it all day! 🙂
Message 3 of 40
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! Do you see "ReCap Photo Service Entitlement"  under Autodesk Account ->Management page? Are you able to sign to ReCap Photo desktop application using Autodesk ID and PW? Do you see "Subscribed" after login?
Thank you and I look forward to your reply.
Anil Mistry
Technical Support Specialist
Message 4 of 40
Anil, I'm having the same problem, I'll answer your questions below... but should I start a new thread given that I'm having the same issue as the OP?
In Cloud Service entitlement I see ReCap Photo Service Entitlement as "29 Days Left".
When using the ReCap photo desktop application I can see my Autodesk ID in the top right hand corner.
Message 5 of 40
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Can you PM your Autodesk ID and screen capture of Autodesk Account page with ReCap Photo entitlement information for further investigation.
Thank you and have a great day!
Anil Mistry
Message 6 of 40
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous and @Anonymous,
Did you install ReCap Photo using these steps:
Installing ReCap Photo (requires subscription to ReCap Pro)
To access ReCap Photo, sign in to your Autodesk Account:
  • Go to the Management tab
  • Select the latest ReCap Pro version and click on “Install Now”
  • Our ReCap Pro installer will then allow you to install both ReCap Pro and ReCap Photo desktop apps
Anil Mistry
Message 7 of 40
Thank you Anil, I will follow the steps to make sure I have the latest version and, if the problem persists, supply the screenshots you have requested. Thank you for your time!
Message 8 of 40
Anil, thank you for your help so far.
I ran the installer again this morning and it tells me that both products (RC Pro and RC Photo) are installed. ReCap Pro version shown is in the desktop is 4.2.1.7 and the ReCap photo version shows as 18.0.0.56, if this helps.  I am PMing as per your request.
Message 9 of 40
devangshah
Hello Peter,
ReMake updates will not be available after November 30th and users are encouraged to switch to ReCap Photo.
However, if processing using EDU license, kindly continue to use ReMake for now. ReCap Photo does not offer free processing to EDU users yet.
We are working towards a suitable solution for EDU users.
You can install the latest ReMake, version 17.25.4.3 from your account at manage.autodesk.com account.
Alternatively, if you have ReMake version 17.25.3.1 installed, then you can update to version 17.25.4.3 using the following update:
http://up.autodesk.com/2018/MMNTO/ReMake_2017_Update_17.25.3.1_to_17.25.4.3.msp
Devang
Message 10 of 40
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @devangshah provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 11 of 40
I've tried installing ReMake on my new Windows 10 build which currently has 3DS Max and ReCap Pro & Photo installed. The ReMake installer tells me that "a newer version of this product is already installed".
Does ReCap have to be uninstalled in order to install ReMake?
Message 12 of 40
devangshah
Hello Mike,
One can either have ReMake or ReCap Photo installed on a machine at one time.
Devang
Message 13 of 40
I am having the same issue. I guess I will go back to ReMake in the meantime..
Is there any chance that ReCap will be available for students by the end of this year (when ReMake is retired)? or will students be forced to pay for a full subscription?
JMM
Message 14 of 40
devangshah
We are contemplating introduction of a suitable solution for EDU users of ReCap Photo which will be made available soon (before ReMake retires).
Devang
Message 15 of 40
Where can I download ReMake now that it was uninstalled on my pc? I can't see anything but ReCap on the ReMake website. Is there still a link for downloading it?
Thanks.
Message 16 of 40
devangshah
If you are an already registered ReMake subscriber or EDU user having an existing EDU serial number, then you can download it from your manage.autodesk.com account.
Else you will not be able to process images in ReMake anymore.
We are working on EDU support for ReCap Photo and that will be available soon.
Devang
Message 17 of 40
Hello everybody,
but what about creating 3D models starting from photos? If Recap Photo wil expire in 30 days (trial version), how will be able to go on with our students?
All the best,
Cettina
Message 18 of 40
devangshah
Hello Cettina,
We will soon be introducing EDU support in ReCap Photo and are aiming for a month end release for the same.
Devang
Message 19 of 40
I am having issues downloading ReMake from manage.autodesk.com. I have successfully downloaded the installer, but when running "Autodesk Install Now" it fails partway through saying "Something is preventing the software from launching. Please contact customer support." (See screenshot) Has ReMake already been dropped or am I doing something wrong?
Message 20 of 40
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, see @devangshah's reply from this post. Let me know if this helps.
Please select the Accept as Solution button if my post solves your issue or answers your question.
Anil Mistry
