ReCap Pro 2026.1 Beta 2 Participation
barmanr
Alumni Alumni
Message 1 of 1
barmanr
We'd like to request your participation in testing ReCap Pro 2026.1 Beta 2.
To do so:
  • Go to https://feedback.autodesk.com/
  • Under Opportunities, look for "Autodesk Infrastructure Futures"
  • Click View Opportunity and apply for access
  • After access is granted, click on "Autodesk Infrastructure Futures" tab menu
  • Click on "ReCap Builds"
  • Click on "ReCap Pro 2026.1 Beta 2"
  • The instructions, release notes, and help doc are attached to the page.
This Beta introduces an Enhanced Update Origin Tool to help orient your point clouds better!
Key Features:
  •  Added support for two-point selection for setting axes orientation for the origin using the Update Origin Tool.
  • Added support for two-point selection using guideline for setting axes orientation for the origin using the Update Origin Tool.
  • Added a History Log section to the Update Origin Tool to track changes made to the origin.
  • Added Inverse location and rotation buttons to the Update Origin Tool to inverse the direction of the XYZ coordinate or rotation angle values respectively.
  • Added support for locking the translation and rotation axes for the origin using the Update Origin Tool.
  • Added support for higher precision for rotation plane angles.
  • Increased rotation range values from -180/+180 to -360/+360.
  • Added support for dynamic update of the axes display when coordinate values are entered in the Update Origin Tool.
  • Added a new button to the Update Origin Tool User Interface to zoom and focus the camera to the origin location.
  • Improved Undo/Redo stability when using the Update Origin Tool.
Bug Fixes
  • Improved stability issues on closing the ReCap Mesh Editor.
  • Fixed security vulnerabilities.
Please post any feedback under User Forums > Reality Solutions > ReCap Pro.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
Replies (0)
