Recap All scans are not found or invalid.
Message 1 of 12
Updated Recap to 4.2.0.2 now we cant import RCP file into AutoCAD 2014.
Attach point cloud failed
If we save in pro the can be imported. They import into AutoCAD2016 ok. We need 2014 because some funcions for ProSteel slicing point clouds does not work in 2016
Replies (11)
Message 2 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! I am not clear here. When you say save in Pro means are you creating project in ReCap Pro and then importing to ACAD 2014? Did you try importing RCS files? I would suggest to try importing as RCS and see if that works.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 12
Recap Pro is correct. RCS files  react the same as RCP files.
What is the differenct between Recap 4.2.0.1 and Recap Pro 2018?
Message 4 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am not sure why you are not able to import RCS or RCP in ACAD 2014. You may want to raise this question in AutoCAD forum. ReCap doesn't control how ACAD opens point cloud data or we never change any process in how its creates ReCap Projects files (RCP and RCS).
Also. Latest version of ReCap is 4.2.2.15. ReCap version 4.2.0.2 is couple of version old. Please, applying following patches:
to update to latest version,
Let me know if this helps.
Anil Mistry
Message 5 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 6 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
Message 7 of 12
I did the upgrades and still have the issue. I will let you know if there is any resolution. Possible recap pro might save the files differently.
Message 8 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, let me know if you are still seeing this behavior.
Anil Mistry
Message 9 of 12
Yes it is still an issue. I am going to just find a work around.
Message 10 of 12
Patrick_Aps_9121
There is no workaround.
Importing Recap files into Autocad (it's called a collaboration model) was introduced with Autocad 2016.
You need to get your other application working on Autocad 2016.
Message 11 of 12
OK,
Thanks for the help.
Message 12 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @Patrick_Aps_9121 provided work for you?
Anil Mistry
