Intensity view problem
rcsoul
Message 1 of 20
rcsoul
The intensity view in Real View shown in Recap seems just a black/white image regenerated  from RGB mode. It is not a real intensity view compared to original one comes from Faro Scene. Thus overexposed views were displayed as shown in the attached image file. Any ideas to fix this?
* Scans were imported from fls file exported from Faro Scene 7.1.1.
Accepted solutions (3)
Replies (19)
Message 2 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
Thank you for participating in our Community! I was wondering what version of ReCap Pro are you using? Would you be able to import in different format like PTG or E57 and see if you are still seeing this behavior.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 4 of 20
rcsoul
Hello @anil_mistry,
Thank you for reply. I'm using the latest version of Recap Pro. I've tried e57 format, it doesn't work. I'll test PTG later.
Message 5 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
Thank you for your reply and I am sorry to hear that E57 didn't work. Please, try PTG and let me know if you are still seeing same behavior.
Anil Mistry
Message 6 of 20
rcsoul
Hello @anil_mistry,
I've tested both PTG and PTS files. But unfortunately none of them works.
Message 7 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I am sorry to hear that. Would you be able to share your project data for further investigation?
Anil Mistry
Message 8 of 20
rcsoul
Hello, @anil_mistry
No problem, I'll upload it.
Message 9 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I just send you A360 project drive invite. Please, upload your project files along with support folder for further investigation. If you have raw data file that would be great.
Anil Mistry
Message 10 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I was wondering if you were able to upload requested file to A360 project drive?
Anil Mistry
Message 11 of 20
rcsoul
Hello @anil_mistry,
I think the files were successfully uploaded. Please check it out. Sorry for late to reply.
Message 12 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
Will download and try to duplicate this behavior on my end and will give you an update soon.
Anil Mistry
Message 13 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I opened provided .RCP and not seeing any odd behavior on my end. I am having trouble importing .FLS but checking with development team see if they can open.
Anil Mistry
Message 14 of 20
rcsoul
Please compare the pictures provided. Although they can be opened normally, the details of overexposed part disappeared in Recap.
Message 15 of 20
rcsoul
Another example is shown below. Details of bright part disappear in the intensity view.
Message 16 of 20
LyleHardin
I'm noticing the same thing when transferring from SCENE to ReCap.
The 'intensity' turns to just greyscale. Very disappointing.
When assembled in ReCap, the intensity works great. When assembled with SCENE, then translated to ReCap, the intensity is lost.
I don't know if it is a SCENE export issue or a ReCap import issue.
It's a bummer, because we rely on the intensity scan to see out through open doors and into dark recesses as I'm sure everyone else does too.
Message 17 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I am still doing further investigation and have asked development team to look into this behavior. I will give you an update soon.
Anil Mistry
Message 18 of 20
anil_mistry
Autodesk Support
Autodesk Support
Hi @rcsoul,
I just got an update from development team saying that Faro SDK doesn’t provide the ability to read reflectance information from colored FLS scan. So, through FaroSDK API, we can only get lightness of color. If you bring in the raw scan and also the color image, ReCap will read the original reflectance information and will also colorize the scan using the provided color image.
Here is detail from Faro SDK document about the reflectance value:
Property scanReflectionMode Determines the way reflection or color values are returned.
  1. For grey scan points: Original reflection value of the scanner. In the case of a FARO Laser Scanner, this is in the range of 0 to 2047.  For color: the lightness of the color in the range 0 to 4095.
  2. For grey scan points: Mapped reflection value is in the range 0 (black) to 255 (white).   For color: the lightness of the color in the range 0 to 255.
  3. For grey scan points: Mapped reflection value is in the range 0 (black) to 255 (white) as  RGB grey value.  For color: RGB color, 8 bits per channel (bits 0‐7: red, bits 8‐15: green, bits 16‐23:  blue).  The default reflection mode is 1.
Let me know if this helps.
Anil Mistry
Message 19 of 20
rcsoul
Hello @anil_mistry.
Does it means registration must be performed in Recap as @LyleHardin mentioned?
Message 20 of 20
LyleHardin
Yeah, I'm a bit confused too. We register in SCENE because it's faster and more flexible than registering in ReCap. So it seems odd than registering raw .fls scans in ReCap works, but importing registered .fls files exported from SCENE loses the intensity values.
