Point cloud has no geographic location
Sylvino
Message 1 of 15
Sylvino
Current and target coordinate system (Canq-M17) has been set in ReCap.
When I  try to attach the point cloud in C3D I am un-able to check the checkbox for "Use geographic location". I could have sworn that I had used this point cloud before and I was able to choose the geographic location.
Any ideas what is going on and how to solve it?
* my company uses a token system so I am not sure if that is the issue?
Replies (14)
Message 2 of 15
ramesh_sridharan
@Sylvino Is you set the CS in ReCAp Pro then there is a possibility that you are trying to import RCS file and not the RCP. Try importing the RCP (which stores the CS information) which will inturn load all the related RCS files from the support folder.
Ramesh S
Product Manager - Infrastructure Solutions
[email protected]
Ramesh Sridharan
Product Manager
Message 3 of 15
Sylvino
I just had a look, and I am trying to attach a RCP file.
Message 4 of 15
ramesh_sridharan
That support folder should contain the RCS files. You should be able to select RCP and import in C3D with CS information
Ramesh S
[email protected]
Ramesh Sridharan
Product Manager
Message 5 of 15
Sylvino
It doesn't seem to be working:
Message 6 of 15
Pointdump
Hi Sylvain,
If your cloud has current and target CS set to CANQ-M17, and your Civil 3D drawing is also set to CANQ-M17, then accept the defaults in the "Attach Point Cloud" dialogue box. Be glad that is greyed out. You do NOT want to ever "Use Geographic Location" in anything you do in Civil 3D.
When you turn on Bing Live Maps in Civil 3D, does it match your point cloud?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 7 of 15
Sylvino
This worked for aligning the point cloud, thank you! Bing map does not load imagery. Could it be that bing does not support this coordinate system?
Zooming out quite a bit the location of my my cursor is the location of the point cloud, and imagery is to the left.
Message 8 of 15
Pointdump
Sylvain,
Bing Live Maps should match your point cloud. In Civil 3D, do you have UNITS set to Meters?
Please post a link to your point cloud. I'd like to test things out.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 15
Sylvino
Units are set to meters. I don't know how to share a pointcloud as the file size exceeds 71mb. If I bring the point cloud into an existing drawing with the same coordinate system the imagery lines up fine. interesting..
UPDATE: It seems like bing does not support/properly display when using the CANQ-M17 Coordinate system. I opened a new drawing and set the coordinate system to CSRS.UTM-17N and it worked.
Message 10 of 15
ramesh_sridharan
@Sylvino If you are using the latest version, you should see the support of ESRI base maps. Can you please check if that gives you the image at right location? (Assuming your units are right)
Ramesh S
[email protected]
Ramesh Sridharan
Product Manager
Message 11 of 15
Pointdump
Sylvain,
You can share your cloud with a link to WeTransfer, DropBox, etc, or a direct link to the site where you got it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 15
Pointdump
Sylvain,
I just looked up CANQ-M17 and CSRS.UTM-17N coordinate systems in MAPCSLIBRARY. They are NOT the same. Very different Central Meridians, False Eastings, and Scale Factors.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 15
Sylvino
I find it interesting that the point cloud lined up properly when attaching it to the CSRS.UTM-17N drawing. CANQ-M17 is the only coordinate system that I was able to use in Recap Pro that had UTM Nad 83 Zone 17N.
Message 14 of 15
Pointdump
Sylvain,
I usually use lasinfo in lastools to verify the coordinate system. That and other metadata are stored in the header of the las/laz file.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 15
Pointdump
Sylvain,
I made polygons of the extents listed in MAPCSLIBRARY for both CANQ-M17 and CSRS.UTM-17N. They're not even close. I think CANQ-M17 is a bad definition. This is why your point cloud looked too far to the right of Bing Live Maps. Here's a visual.
Dave
Dave Stoll
Las Vegas, Nevada
