What is the proper work flow to extract ground points only from .LAZ
Hi all, I'd like to ensure that I am using the proper workflow to extract ground points only using Recap Pro 2025.
Step 1: Create project, set coordinate system, and import data (decimated to 100mm) Also is it possible to add coordinate systems to Recap?
Step 2: Index scans then launch project
Step 3: My data already has classification so in the classification options I delete everything except for OG and low vegetation by selecting the "X" beside each classification. I find this helps speed up the next step.
Step 4: Optimize the project since I deleted points
Step 5: Automatic ground classification using optimum
Step 6: Save and optimize
Did I do this correctly? Since the laz file is already classified, could I have skipped step 5?
Also, how do I see how many points my project has?
Link to las file:
