What is the proper work flow to extract ground points only from .LAZ
Sylvino
Sylvino
Hi all, I'd like to ensure that I am using the proper workflow to extract ground points only using Recap Pro 2025.
Step 1: Create project, set coordinate system, and import data (decimated to 100mm) Also is it possible to add coordinate systems to Recap?
Step 2: Index scans then launch project
Step 3: My data already has classification so in the classification options I delete everything except for OG and low vegetation by selecting the "X" beside each classification. I find this helps speed up the next step.
Step 4: Optimize the project since I deleted points
Step 5:  Automatic ground classification using optimum
Step 6: Save and optimize
Did I do this correctly? Since the laz file is already classified, could I have skipped step 5?
Also, how do I see how many points my project has?
Link to las file:
 https://www.dropbox.com/scl/fi/fhxhacsochavgnd976kys/LiDAR-clipped.laz?rlkey=ewnebugfedw20u97l4lko33...
Pointdump
Sylvain,
Thanks for posting link to your data. I'm loading it right now.
"Also is it possible to add coordinate systems to Recap?"
Yes. You can create a custom coordinate system definition in Civil3D/Map3D's MAPCSLIBRARY and ReCap will read from that.
"Since the laz file is already classified, could I have skipped step 5?"
No, because step 3 still has "low vegetation". After you use automatic ground classification you need to delete everything but the Ground(2) classification before exporting.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Pointdump
Sylvain,
Reading the header, lasinfo in lastools shows your point cloud is in >>>EPSG:2958<<<, NAD83(CSRS)/UTM zone 17N.
Dave
Edit: More info
WKT OGC COORDINATE SYSTEM:
COMPD_CS["NAD83(CSRS) / UTM zone 17N + CGVD2013 height",PROJCS["NAD83(CSRS) / UTM zone 17N",GEOGCS["NAD83(CSRS)",DATUM["NAD83_Canadian_Spatial_Reference_System",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6140"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4617"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","2958"]],VERT_CS["CGVD2013(CGG2013) height",VERT_DATUM["Canadian Geodetic Vertical Datum of 2013 (CGG2013)",2005,AUTHORITY["EPSG","1127"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","6647"]],AUTHORITY["EPSG","6660"]]
histogram of classification of points:
4236041 ground (2)
5606353 low vegetation (3)
5174022 medium vegetation (4)
42568209 high vegetation (5)
53233 noise (7)
1472 Reserved for ASPRS Definition (18)
Dave Stoll
Las Vegas, Nevada
