ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
pipe snap tool tip missing recap 23
4 REPLIES 4
clomedico
200 Views, 4 Replies
In the previous version of recap there was a tooltip that would give info (diameter) on the pipe that was dimensioned using pipe snap.  it appears to be missing in recap 2023.  can anyone verify?
4 REPLIES 4
Thank you for upgrading to ReCap 2023.
I used ReCap 2023 and I can see the diameter.
Do you have a screenshot to illustrate the issue?
May I know which version did you use before upgrading to ReCap 2023?
Klarinda
Klarinda Gunadi Widjanarko
Senior Software Engineer
using the latest version before this one.  see attached screenshots
I have two display monitor and I have changed my 2nd monitor resolution to 2560 x 1440 and 100% scale. Unfortunately my 1st monitor does not support that high of resolution so the max it can go is 1920 x 1080.
I still can hover on the annotation and see the tooltip.
Please hover on the end point instead of the middle point to see the pipe snap tooltip and the + sign.
Please see gif image below to illustrate.
Hope this helps.
Klarinda
they are still not there.  will try lowering my display settings to see if that works
Rail Community
