In the previous version of recap there was a tooltip that would give info (diameter) on the pipe that was dimensioned using pipe snap. it appears to be missing in recap 2023. can anyone verify?
Thank you for upgrading to ReCap 2023.
I used ReCap 2023 and I can see the diameter.
Do you have a screenshot to illustrate the issue?
May I know which version did you use before upgrading to ReCap 2023?
Klarinda
using the latest version before this one. see attached screenshots
I have two display monitor and I have changed my 2nd monitor resolution to 2560 x 1440 and 100% scale. Unfortunately my 1st monitor does not support that high of resolution so the max it can go is 1920 x 1080.
I still can hover on the annotation and see the tooltip.
Please hover on the end point instead of the middle point to see the pipe snap tooltip and the + sign.
Please see gif image below to illustrate.
Hope this helps.
Klarinda
they are still not there. will try lowering my display settings to see if that works
