Output and Temp Folder size adjustment
I need to change my output and temp folder size from 3833 MB to 14800 MB. How do I make these changes so I can open up project files?
Paul
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous.
Thank you for participating in our community! Are you trying to increase Memory usage and change Temporary File Location folder? You can change temporary file location and memory usage by doing following:
  1. Click on “Preferences” of “CTRL+P”
  2. Click on “Files”
  3. Click on “Temp”
  4. Select New Folder location
  5. Click on “Advance”
  6. Uncheck “Auto” box from Memory Usage section
  7. Make necessary changes
  8. Click on “OK” to accept changes
Thank you and have a great day!!!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if my post helped you with your question. Please, select the Accept as Solution button if my post solves your issue or answers your question.
Let me know if you have any further questions or concerns.
Anil Mistry
