I have setup of Decap to run multiple instances for the purpose of batch processing across different cores on the PC (4 projects, each to use 2 cores). I have come to realize that the license check (either decap.exe or adskFaroConverter.exe) has halted this process and causing all projects to infinitely process and never finish.
When running multiple instances of Decap, All instances will hang up and stay idle until forced to close at around 2-3% completion.
I am curious to know the logic of creating a command line feature that doesn't allow someone to perform batch processes.
Please, if there is a work around let me know.
Example: I run for decap executions on separate files. license shows to validate on all four, however at[1 9]-[3 9] all instances will get "stuck" and stay at the same percentage unless they are force closed.
If i run just a single instance, everything works just fine. I am open to suggestions here but I need to be able to processing multiple projects at a time.
