ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Mouse icon selection issue
4 REPLIES 4
Fueler
567 Views, 4 Replies
Trying out Recap and just getting familiar with what is where.
I have a problem with the mouse flyout. The first time I tried it I chose orbit and life was good.
To get out of orbit I had to use escape.
When I went back to the icon to choose something else, the flyout appears, then the popup in the photo and then it all disappears before I can do anything.
I had to be really quick on the screen capture button to get this.
4 REPLIES 4
vikas.vaishnav
in reply to: Fueler
Hi @Fueler
The flyout is not a menu that you can select. It is like a tooltip image showing you interactions tips while using mouse. If you hover your mouse cursor over window selection menu it shows up. While using mouse scroll you can use these mentioned key to observe specific behaviours.
Hope this helps.
Vikas.V
User Experience, Autodesk Recap
Link Name | Link Name | Link Name | Link Name
Fueler
in reply to: vikas.vaishnav
OK. Cool
Mine blinks in and out so fast that I only knew what it said by grabbing that screenshot.
anil_mistry
in reply to: Fueler
Hi @Fueler,
I'm just checking in to see if you need more help with this. Did the suggestion that @vikas.vaishnav provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Vikas: I see what you are saying, but the screen flicker is extremely annoying. Just saying.
Rail Community
