Trying out Recap and just getting familiar with what is where.
I have a problem with the mouse flyout. The first time I tried it I chose orbit and life was good.
To get out of orbit I had to use escape.
When I went back to the icon to choose something else, the flyout appears, then the popup in the photo and then it all disappears before I can do anything.
I had to be really quick on the screen capture button to get this.
Solved by vikas.vaishnav. Go to Solution.
Hi @Fueler,
The flyout is not a menu that you can select. It is like a tooltip image showing you interactions tips while using mouse. If you hover your mouse cursor over window selection menu it shows up. While using mouse scroll you can use these mentioned key to observe specific behaviours.
Hope this helps.
OK. Cool
Mine blinks in and out so fast that I only knew what it said by grabbing that screenshot.
Hi @Fueler,
I'm just checking in to see if you need more help with this. Did the suggestion that @vikas.vaishnav provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
