ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
LEICA FILE IN RECAP
9 REPLIES 9
Message 1 of 10
PACDrafting
1006 Views, 9 Replies
LEICA FILE IN RECAP
We have a Leica file and have imported it into recap pro. But it seems to be removing 60% of the points. We have turned off decimation option.
Why is it removing all of these points?
I’m aware this is not the appropriate scanner used but not sure on points being removed??
9 REPLIES 9
Message 2 of 10
PACDrafting
in reply to: PACDrafting
I can't seem to attach the file
Message 3 of 10
danny27585
hello,
What kind of leica file are we talking about? do you have cyclone?
Message 4 of 10
PACDrafting
in reply to: danny27585
Hi
It’s a LEICA P30 scanner. Probably not the correct scanner for this
requirement but why is recap only importing 5000 points? Compared to
Geomagic Design X or even Microstation importing the full 27000 points
Message 5 of 10
danny27585
I used to work with a Leica P30, never had a problem. My workflow was process via Leica Cyclone and unify, export to PTS (or E57) and import to Recap. Can you share your workflow?
Message 6 of 10
PACDrafting
Thanks for the reply
Unfortunately the facts are its not importing to Recap correctly but is fine with Microstation and Geomagic design X. Also I have only received the pts file off someone to inspect the reason its not importing correctly. I'm assuming their workflow to get the pts file is likewise with our method.
Message 7 of 10
PACDrafting
your method....that was suppose to be
Message 8 of 10
danny27585
Well if someone else processed the data maybe you should ask if they used a decimation grid? (something very drastic 50mm etc) you could try asking for a e57. The people that made the imp "leica file" should be able to fix this very fast and could actually make the RCP for you.
Message 9 of 10
PACDrafting
I understand that
But try to explain why it imports correctly into the other apps I mentioned?
Message 10 of 10
danny27585
Im just going to take a guess but it may have to do with the decimation grid turn it on and give a 2 or just live at 5 see what happens....
Rail Community
